can someone who really knows..explain the differences between anodized and polished and clear coat ect ect..
Some people can;t tell the difference
Ant
Anodized = Is a electro chemical process that is applyed in a tub. Its rather hard to do at home and requires special equipment. The finish is resistant to corrossion and adhears to the surface better than Clearcoat/paint therefore making it a stronger sheild against scratching etc. It absolutly hates ACID and any Similar chemical cleaners especially OVEN CLEANER, Anodi can be removed using chemicals like this so steer clear.
Polishing= Is a process that invloes grining down the material smooth until its own elements make up a corrosion resistant barrier. It requires frequent maintanance because it is not as protective as Clearcoat or Anodie,but looks amazing.
Clearcoat= Is similar to paint and just froms a sheild over any material , it prevents corrosion build up but is prone to cracking , scratching and depending on its base can be weaked or removed by most laquor and alcohol thinners. Through it works care is required when working with clearcoat.
Thats just off the top of my head , if anyone would like to add anything please do.
As for the rims if they are infact anodized you wont be able to remove it with a mild metal polish. If its on bare surface and is actually the corroding aluminum puffs then you can get it out with any mild polish. If i were you i would probably look into polishing them up and using a good sealer. Then just frequently maintain them.If you daily your car id say either powedercoat or clear. GL let us know what works out.
