What tires are you running? Tires are a big factor (the biggesr factor) in wheel hop. For this reason, one tire to definitely AVOID is the Michelin Pilot Sport (PoS).ktrends said:What can i do to take care of a serious wheel hop problem? It has just gotten worse since I installed my new "az" clutch.
I am also running nittos could these have anything to do with it?
I hope (and believe) that the clutch breaking in will at least help slightly.....ktrends said:Andi-
I am running nitto 555R's, I also am useing a stock flywheel. All suspension is STOCK. I think breaking the clutch in really well will answer some of my problem. I just wondered why I hadn't heard anything about wheel hop before?!
Yes, this is the cause of your problem. (Unless you are talking about the Drag Radials, which I assume you're not)ktrends said:I am also running nittos could these have anything to do with it?
