1 - 3 of 3 Posts
Defender of the Universe
Can someone please give me the correct wheel offset and bolt pattern for the stock 17 inch wheels? I am trying to find aftermarket 17 x 8 and 17 x 9.5 that will fit the tires i have now but I do not know the correct offset or bolt pattern. Thanks to anyone who can give me this information
The lug pattern is 5x114.3 and the stock offset (front and rear) is 50mm. You of course can use quite a few different offsets depending on the size tire you plan on running. I wouldn't go any lower than a 41mm offset in the front and a 45mm offset in the rear.
Later, Steve
thanks a ton, this helps alot
1 - 3 of 3 Posts
