1 - 7 of 7 Posts
I seem to have two wheel studs that are showing signs of wear,difficult to screw on lug nut. Any low cost ideas for replacement.
Sure. Stock are $2 per. Get 'em and replace. VERY easy job.
Shit -- I can mail you two extras if you want.
Is there a longer alternative? We have used AP's but the knurl is not the same. Someone suggested Land Cruiser ones??
Thanks for the offer I will order some from the local toyota place, can you give simple instructions I have never replaced wheel studs before.
Terry - use some kind of a drift to bang out the old stud if it's broken. Otherwise just use a 5 lb sledge.
Then rotate the hub until it aligns such that you can slip the new stud in from the back.
Next, get some kind of ~1/2" thick cylindrical object to use as a spacer. An old pilot bearing will work. Place this over the new stud as it protrudes through to the front side of the hub.
Use a lug wrench and a lug to "suck" the new stud into the hub all the way.
Voila!
If that's not clear enough let me know and I can take some pics or something.
-Chris
I thought someone mentioned H&R made some that worked for our car. They were a better length than I believe some of the better known ones that the drag guys use.
1 - 7 of 7 Posts
