1 - 20 of 3082 Posts
(Rare & Unique)
For those who have pulled or done more than usual rear fender mods (not WB), what size wheel you run out back & offset ? I'm well aware of 11.5" rears fitting w some cutting/rolling but wanting to see what was out there that was 12"
I know the back spacing will be somewhat standard so the rest will fall on the front spacing.
TIA
Rik
(Rare & Unique)
Let's say 335 tire on a 18" wheel & not a huge deep dish wheel lip but decent enough.
You think there would be alignment issues as in negative camber/contact patch ? If so, how do the wb guys do it? It's still the same rear suspension.
Blood for Blood
I might be doing that soon... a 335... but what you need to understand that not all 335 wide tires are the same, some companies are wide and some are not.
there is a guy on here that just has a cut and he has 335 rears...but I dont know his rim size... He has a ren red supra.
I have ccw classics 18x11.5 and run 315 30 now... I am going 325 30 soon... I still have alot of rim... I might be able to do 335 on my 11.5 ccw classic rim. I just have a rear fender roll and not a cut.
why do you want 335's?
(Rare & Unique)
I think 36chambers run 335 on stock body w/fender cut.
I'm aware of the tire size in both width & height fitment as i had a few from the past. Like how BF's are "meaty" in height & some of the other brands in terms of sidewall construction and whatnot as a few examples.
I think i want 335's for the same reason you do Rogue :) especially the look outback
Blood for Blood
Yea I think thats his name... he has a pic of it in his sig... I talked to him about the cut vs roll along time ago. I just want to do 335 to fill out my rim... lol I need it for the street I need the grip.
where have you found a 325/30 18?
TIA,
craig
What do you mean where? You can order them or buy them in person. Most of the time you have to order them. Are you asking the brand cause you can not find them? Michelin makes 325 30 18's man.
...What do you mean where? You can order them or buy them in person. Most of the time you have to order them. Are you asking the brand cause you can not find them? Michelin makes 325 30 18's man.
ha, guess i was a little vague.
Michelin huh? you'll have to direct me... i've only seen 325/30's in 19's.
craig
Blood for Blood
Yeah just a little vague so I had to ask.
Yes Michelin is not the only one that makes a 325 30 R18 man.
Have you checked online?
Yeah, all over - having no luck... I found a DR in 315/35 18 (m&h, hoosier, or toyo - i can't remember which), but other than that, i've only found standard sizes in 18's: 305/35, 315/30, 335/30, 345/30... no 325/30.
post a link?
TIA,
craig
It's all ball bearings...
RikTT: You may want to contact Ron (StSupDog) since he runs 12" wide HREs on his MKIV. Here's a comment he made on his wheels from that thread:
The 19x12 were not easy to fit under the stock body... but, they did :), I first tried the 315/25 r19 but, had serious traction issues and the side wall was real thin... Continenetal width specs on "their" 295/30 r19 were just as fat as the 315/25 so I tried them and they work Great! 295's on a 12" lol but, trust me when I tell you it is basicly a 315/30.. here's a pic of my wheel with no tire..
I also recall him commenting somewhere else that he had to do some serious hammering on the inner fender well to get enough clearance for the 12" rears. Hopefully he can lead you in the right direction, he was very helpful when I contacted him about how he did his S2K seats install, so you should be good to go. I hope that helps, good luck!
Chris
(Rare & Unique)
Discussion Starter · #12 ·
Chris, thanks for that bit of info. I have planned well ahead several months ago for this step so this feedback is great. I'll contact StSup, Ron for his thoughts as well.
I'm concerned with the contact patch at this width on our cars. Most of the rim will be front spacing as the back spacing can only be but so wide. Throw in the lowering factor and it may present some issues. I'm not crazy low btw.
Anyone else with pics ?
i know this is about stock body w pulled/rolled fenders but my 19x12's fit very tight but i didn't have to beat the fender well in like i've seen on some cars. Some i've seen i done to didn't even have 12". I have a 7" backspacing with a 5" front spacing. When i jack mine up they are hard to turn seeing with the suspension all the way out the sidewall rubs. With regular weight all is well. Im running a 345/30 and I'm not sure on my offset. I wanna say +23 but im not positve.
I commented on this as it pertains to the amount of back spacing. The 7" measurement came from when i was taking wheel measurements to have my wheels made. I may still have them but they are not hard to take. I dont know the amount of front spacing on the stock body so i cant really help there.
i know this is about stock body w pulled/rolled fenders but my 19x12's fit very tight but i didn't have to beat the fender well in like i've seen on some cars... I have a 7" backspacing... Im running a 345/30 and I'm not sure on my offset. I wanna say +23 but im not positve...
so you're running a 19x12 under a stock body? can you post some pics... particularly some that clearly show how close to flush they sit?
this is interesting b/c conventional wisdom says 'no way' a 345/30 mounted on a 19x12 should fit under a stock wheel well.
and your offset should be 1" or 25.4mm right? midline of a 12" wheel is 6" on either side... 7" BS leaves a 1" offset, no?
i'm very interested b/c my own fitment is a little unconventional and i may want to try some 335's. car should be done in the next couple weeks. current rears are 315/30 MT DR's on 18x11.5's. two odd things though:
1. the sidewalls don't cover the outer edge of my wheel at all (almost like a stretch fit - outer edge protrudes like a curb feeler!)... i'm wondering if a 335 might fit the wheel better.
and...
2. my builder (one of the most reputable on the forums), said that the 315's on 18x11.5 + 52's fit under my STOCK fenders - no roll... no cut... no pull... no beating the inner well. and the car isn't lifted in the rear (Tein RE coilovers). i can't explain it, but i'm hoping i might have room to try a larger tire (either 335's or the 305/35 MT's).
craig
No, ...It was NEVER NA!!!
Im running a 17x11.5 right now with a 10mm spacer, and Nitto dr 315-35. I could easily change my outer barrel to one .5" larger. In fact, ..I might just do that in a few months. Just not a priority right now. My fenders are rolled flat, btw.
T1 TUNED
i would like to see some pics as well.. on there cars
I have a Trd widebodykit. I was only commenting on the rear portion of the wheel. i was saying i know how much can fit in the back but not the front of a rim for a stock body. I will find my measurement sheet from when i ordered my wheels to get the exact size and offset in the a.m.
T1 TUNED
pics pics pics please post your 12in wheel on your car
