Okay, may be a dumb question, but I am stumped. On the intake side. Lets start with the first hose. I am referring to the one that is connected by a banjo fitting on top of the fuel rail. It's the one next to the mushroom cap on the firewall side of the rail (NOT on the FPR side). It has the length to reach the cold start injector up under the upper intake manifold, but I don't see how it would be incorporated there. The CSI already has a banjo fitting on it that leads to the "J" line (which I did remove with the help of a new block off plate). So, where does this go???
Second question. it's about the mushroom cap on the firewall side of the fuel rail on top. This has the crazy stair step hard fuel line that goes down between the 4th and 5th runners of the lower intake manifold. It has a banjo fitting on the end of it as well. Where the heck does it hook too? On the motor mount, held by two 10 or 12 mm bolts is that fuel bracket. on the bracket, there is a banjo fitting and a pipe attached to that. I know there should be a hose that fits onto the end of that, but where from? Does the stair step hard line have something to do with that motor mount fuel bracket?? I am friggin' confused. Pics would be great if someone has some of there stock setup
Trev87supraturbo
Trev87supraturbo
