1 - 7 of 7 Posts
My gas door wasnt opening so when I was reaching back to pull the lever inside the hatch where the light is to open it I noticed this line. It seems to run towards the rear bumper. What is it or where should it be connected to?
It's only the beginning..
Totally can't see the pic... too dark..
9
Good try w/the pic, but it is hard to see the details. Regardless, it does look like the drain for the antenna. Check the following; if the upper end is attached to the bottom of the antenna motor, the other end should be running down and out to the ground I believe.
1 - 7 of 7 Posts
