1 - 7 of 7 Posts
tranny mount, theres four bolt right by the wire, just undo one of them and stick it there
The bigger long ones on the outside that sit higher up or the 4 that are all grouped close together near the ground? I think I'm going to put it on one of the bigger ones higher up... Don't want the wire to get snagged on something while driving...
Thanks,
-Dave
i put mine of the one of the four, thats what guys in my area do to
Buddy thought I had a NA
it's ground wire put where ever it will reach on the body
25psi = 14" brakes :)
Pretty important to have a good ground in a few places.
Head.
Block.
Transmission.
I've also added a ground to the alternator mounting bolt, as that's where the power is coming from, and I don't want to create a loop through the engine if you know what I mean.
When the power grounds out, and uses the coolant to do it, your softer metals start to come apart. (Ever see what this can do to your coolant passeges in the head? It can ruin a nice engine in a few months if the engine has no other grounds.)
1 - 7 of 7 Posts
