1 - 20 of 20 Posts
Track Junkie
I posted this problem a while back, but didn't get much response.
Anyways, I got the torque converter rebuilt by Midwest, and installed 7200cc fuel system. now, the problem is still here, can't exceed 370rwhp. My Supra is making same exact horsepower with a GTE61p and GTE67P. According to Midwest, I don't need to lockup the converter and I should getting all the powers to the wheels.
The shop built my turbo kit did a compression test and no problem find. Transission was fairly new rebuilt by Boostlogic in July and car has not driven more than 200miles since then. I am currently using AEM v1.03 map, converted from v.94. Did I miss something in the AEM configuation? I am using GM3BAR sensor, GM IAT. Anyone has a SP67 or PTE67 auto map that can send me so I can take a look? I would be really appreciated if anyone can help me out.
Thanks in advance.
Chinchi
King of the NA-T's
Got a log file of your pulls? specifically ign timing, a/f ratio, boost, etc.
You were told you dont have to force the torque converter to lockup, esp. on the dyno..............doubt it...?
dc
Track Junkie
I think you misunderstand what I said. What I meant is even without lockup, I should get good amount of power on the road or on the dyno.
Who has done the work on your car? You should be able to make ~450rwhp atleast on pump gas with the converter unlocked. There is something very wrong.
How does my exhaust smell
I would bet the timing is too low (3-4 degrees at peak torque). You need to post up the logs so we can see. It would also help if you posted your current map.
I can post up my map for you (67GTQ, 850CC, BUILT AUTO), but we should probably see whats wrong with yours first.
Pays Cash, No Questions
Yes, please do post up your maps - as a previous AEM user, I would like to see what's going on...
post your map.... and the log.... be sure you monitor the transmission parameters, ignition parameters, and fuel paramters.
Justin
Track Junkie
Discussion Starter · #10 ·
trying to get the shop guy to send me the map and logs, but appearly he is too busy with his other customers. I'll post them up as soon as I got them. Also, he told me that it was running on 24 degree with 12 A/F ratio.
Bad Karma Supra
oohh - was the knock table logged by any chance too? 24deg @ 12:1 a/f...becareful man!u
King of the NA-T's
I don't have ver 1.03, so I didn't look at the cal file. The log file doesn't have your ign info on it, do you have a different log file with more engine parameters?
Track Junkie
Discussion Starter · #17 ·
Here is the old .94 version. Dan said his computer will lock up if logging too many files. I can ask him to log more if needed.
AEM v.94
have you done a compression test? the tranny looks to be fine, the convertor looks to holding the lock up. so it's go to be in the tuning. Tuning a "load down", or "reverse load" on the dyno to see what your drivetrain losses are.
Justin
King of the NA-T's
[email protected]!! Those are some aggressive timing maps! I hope you run race gas all the time! A log file with engine parameters would still be good, especially with knock data. I too would suggest doing a compression test.
1 - 20 of 20 Posts
