1 - 3 of 3 Posts
I am not sure what the item is called in the center of the pic but need to know where to hook it to. I traced it (vacuum line?) across the engine and down between the head and the intake. Then I just have a hose hanging below the intake and can't figure out where to attach it. Thanx
way over budget
it should have started at your bypass valve, gone to a little hard line that goes along the isc hardline, then soft to hard again then back to soft under the intake manifold. there is a little nipple for it on that little vaccum rail that is bolted to the intake manifold. The nipple will be facing towards the engine.
1 - 3 of 3 Posts
