1 - 10 of 10 Posts
Last stock TT on Earth
Like the title says, I'm yanking the rotors off this weekend and if the local hardware store doesn't have this size bolt, are there any bolts on the car that are not "critical" that I can use? (Say if the bolts are damaged I can still drive my car for a few days while Curt sends me some more...)
By the way what is the meaning of x1.25? Is it the distance that contains 5 revolutions of theading or something? (I'm a ChemE not MechE :D )
Thanks.
Real common. Your parts store will have plenty. If you can't get to one or something, search around for a bolt that has a 12mm head that doesn't look too important and it'll probably be 8x1.25. You can grab one where the plenum mounts to the lower manifold. Might leak slowly but it should be fine once you put it back in.
1.25 = 1.25mm / thread
edit: ^
Chucky Doll said:
Ace hardware, Lowes, Home Depot... they all have it.
I went on my lunch break to Ace.. to get some bolts for my turbo and stock O2 bung... found everything i needed.... the only probelm you may run into might be length but a hacksaw will fix that.
Thanks everyone. I am planning on going to Ace anyway to pick up a rubber malet in case these bolts + blow torch (aka the blue wrench) don't work. I have a feeling that the rotors are going to be a bitch to get off since my car is very familiar with the winter.
Yeah, you can't be picky about the length.. just be grateful they have them :lol: How's the car coming along? We'll have to meet up sometime..
It's not that bad. Just get a good quality grade 8 bolt. Make sure your e-brake is down and just slowly thread the bolt in. You'll see the rotor slowly start to come off. Good luck :)
1 - 10 of 10 Posts
