1 - 9 of 9 Posts
My power steering rack is leaking from the right seal in the boot. My car has been unused for 2 years waiting for me to finish my BHG rebuild. It did not have this leak when i last drove it. I am wondering if with out the pump pumping that when i turn the wheel it had too much fluid in that side of the rack and blew the seal temporarily or permanently?
Napa wants about $350 with out the evo valve and $465 with the new solenoid. A rebuild kit for the end is $75 but who knows if the other side would blow too. My car has 220,000 miles on it so i bet a new one would perform better.
What are y'alls suggestions and where should i buy a new/reman rack?
Thanks,
7
GO TO YOUR LOCAL PICK YOUR PART TYPE JYD AND GET YOURSELF A COMPLETE RACKFOR A WHOLE LOT LESS . JUST LOOK AT AT IT CHECK IT FOR OBVIOUS LEAKS TURN THE WHEEL MAKE SHURE IT MOVES SMOOTHLY THEN TAKE IT OUT
0 to gas station in 5 sec
I seem to remember got a reman'd rack from Autozone for $200. Worked great.
Matthew 6:33
Mine was arond $450 with PPS solenoid. I would not go the junkyard route.
TheFastCoonAss
I bought the complete rebuild kit from Champion Toyota for $40.00, although, it's not the easiest thing that you'll ever rebuild.
1 - 9 of 9 Posts
