1 - 13 of 13 Posts
Does anyone know a good place (in calgary) or chain of service stores (anywhere in Canada) where it would be a good place to get some coilovers installed?
Removing old shocks:
Loosen lug nuts
Jack car up
Remove wheels
unbolt strut tower nuts
unbolt upper control arm
unbolt the the lower mount for the shock
Remove shock
Reverse to install
^ That is for the fronts. I dont recall if you have to move the control arms around on the rear. But the hardest part of the whole thing is removing and install the LONG bolt for the upper control arms.
Adam...ya only have to do the big control arm bolt for the fronts. the rears are easy as hell.....Actually, the big bolts weren't even hard on mine, just yours... :p
But expect maybe 4-6 hours depending on how fast you work...Bolts will be seized so have a big bar for leverage or know how to use your feet :D
Dr. Jeff Lange
Took me about 30 minutes for each rear, 30 minutes for the front driver's, and about an hour and 15 minutes for the front passenger... stupid upper bolt is a pain to get out (wasn't seized, the washer resevoir is in a bad place, lol, took a while to maneuver it out).
Dr. Jeff Lange
I wouldn't pay a shop to do it, it's very easy.
Tein Flex here.
I will be putting them on myself as soon as the Supra is out of storage and the coilovers arrive... Tein Flex's as well.
Psychot, have you already bought a set or are you still looking around?
Jim
Dr. Jeff Lange
Jim, you got Tein's!
Sweet... you'll love em.
Local Tire Destroyer
if you are quick i would say 3 hours
add 3 hours for learning and stuck bolts
if you screw up, you can always tow it down to a shop
but you should be able to complete this operation
i personally am running the jic magic system
i purchased it in japan, and had it sent with my wheels
1 - 13 of 13 Posts
