1 - 2 of 2 Posts
I dont have pics, but its on the side of the rear thermostat housing (not the front part with 3 bungs). On the rear part of the housing there are two things sticking out, one, on top has a big green plug and just underneath is the coolant temp sender with 1 wire going to it. IIRC you need to take the power steering reservoir bracket off and move the reservoir to the side to get to it. You can barely see it with all that shit still in place. Also if you're gonna look at any diagrams or parts, the unit is called coolant temp sender, not sensor.
HTH
1 - 2 of 2 Posts
