I'm expecting 1000+rwhp out of my new setup and now the question is which tranny should i use. Or will the stock one hold.
Thanks in advance
Tj
Thanks in advance
Tj
What kind of tranny? Post op? Pre op? Well if you're going with the six speed, you'll be fine. Just get a Tilton if you can afford it, and RPS clutch.
If you're going with an automatic. Go with a built unit from BL or SP, or a TH/SP/BL400.
You want him to get two clutches?Just get a Tilton if you can afford it, and RPS clutch.
There is no built Toyota tranny in the world that can handle 1000RWHP reliably.
I had spent most of the morning, taking time out of my vacation, to deal with stuff from work. My brain was fried from the BS.You want him to get two clutches?
that would be much better but little expensive for me.Or a built 4L80E...
And a lock-up converter is underrated! I would take a lock-up converter over an extra gear any day.overdrive is overrated![]()
