Which Turbo?
1082 Views 10 Replies 3 Participants Last post by  Ebanks
Which Turbo should I buy? A T04R or a T51R? I hear the TO4R produces 675hp with little lag, and the T51R produces 700hp with moderate lag. What do you think?
1 - 11 of 11 Posts
t66!!!!!
t04r wont produce 675 wiht little lag, its going to lag, that would take like a .90 ar housing, which is laggy...ive never seen a t04r produce that much on a smaller ar housing...
Well first of all I think you've picked 2 of the top single turbo upgrades to choose from. Deciding on one is dependent upon your driving habits and expectations. Is this for racing or for street, if for racing, then what type drag or open track? Most everyone tends to focus on maximum horsepower at maximum RPM. Sure, at near 7000 rpm some develop 700hp, but at 4000 rpm may slowly be rising to 200hp. Where as a set-up rated at maximum 600hp is rapidly passing 400hp at 4000 rpm. How much response or drivability are you willing to sacrafice. To me 600hp or 800hp your already well past 500hp!!! Are you really going to notice the difference between 675hp and 700hp? Probably not, but you will notice when your power comes on and how long you can use it for, untill you have to upshift into another gear. The nice feature I have found with the Garret turbos is the availability of different sized and types of turbine housings which are easily interchangable. The To4R kit comes with a single-port .96A/R exhaust housing. There is the larger dual-port 1.15A/R which will give you more hp or a smaller dual-port .84A/R which will give you better response. There's even a single-port .81A/R and a dual-port .70A/R available which are all easily interchangeable for about $100 per/housing. Unlike the T- 51 the To4 offers the dual port exhaust design which allows for increased velocity with-out sacraficing flow. This responsive dual-port design only works with a well designed dual-port header, such as HKS offers. The T-51 kit has the same high HKS quality but with a new round single-port 1.00A/R turbine housing and a 6to1 round header. The newer T-51 also adds a unique secondary type inlet on the compressor which I have yet to understand but I can assure you it's no gimmick.
See less See more
go with the .70 ar housing in my opinion....:D
Well, this is for street. I want the Turbo to produce between 650-700hp. I like the TO4R, and someone said that it did not produce 675 hp, well then, how much hp does it produce?
How much does a hp does a T-88 give? What about a T-66? Is a T-78 the same thing as a T-88? I want 650hp-700hp on street. I wanna run a max of 35PSI(not on street;) ) thanx alot you guys!
get a big housing SP63.
-Ethan
how much HP does the SP63 make?
650-675 RWHPish with the big housing, and it spools fast as hell.
-Ethan
1 - 11 of 11 Posts
