1 - 9 of 9 Posts
gt35/40?
just as the title states..... which clutches convert it to push style.... as i am having a great amount of problems with the pull style assembly of the stock clutch system.
Now I'm confused on the push-pull thing but if you don't have it backwards, if the stock setup is pull then my HKS triple is push. I think the Tilton is also push type, maybe also the Exedy twin and triple are push, not sure what else. I'm pretty sure the TRD twin is same pull mode as stock.
Exactly what is your problem with the stock pull setup? That setup works so maybe your problem is rooted in something else.
gt35/40?
snap ring keeps coming off, even had a supra guy around here who has done a few clutches look at it as well he is just as puzzled as me
oz_soarer said:
OS Giken are push type clutches.
ahh yes, those are too.
Did you try a new snap ring? I'm guessing you probably did, but a worn or distorted ring might not hold; or if the groove is distorted or worn or filled with dirt so the ring doesn't seat properly. Otherwise, that ring should be able to hold more thrust than it sees.
gt35/40?
yes i used all new everything, the only thing i did not replace was
flywheel
clutch
clutch cover
and fork
next time around im replacing all of that see if i get better luck!
1 - 9 of 9 Posts
