All right guys, I need someone to tell me I'm not insane over here.
I bought some whiteline adjustable rear endlinks (KLC141), and I'm trying to keep everything the same orientation as stock when replacing them, but:
The endlinks are longer and thicker than the OEM ones, so they are hitting the coilovers when I try to insert it in the LCA. Unless I flip the orentation where I insert the joint on the other side of the sway bar, I don't see this working out.
Am I insane, or does this really look like it doesn't fit? I'm assuming that Whiteline has labeled them wrong on their website, as there is another set of endlinks labeled as "front" (KLC139) but seem shorter than the KLC141.
Top pic is showing how the end link is so close to the strut, so I can't even lift it up to insert it into the LCA
Bottom pic is OEM endlink on the opposite side of the car
Edit:
Emailed Whiteline. I'm almost positive they mislabeled their products, but I am extremely disappointed. Gonna try to return it for a full refund, but I've already purchased a SuperPro rear links instead. What a waste of time...
Edit:
