yeah, but you have a vpc too, that definitely helpsRocky28072 said:dont see how "typically standalone cars make 100 more rwhp" but I did 480rwhp/430rwtq on VPC/SAFC combo back in october. I'm sure its over 500whp now since I've added a fmic
I forgot where, think it was some northeast people, they had to fly this tuner in from another state to tune the AEM on a bunch of supra'smogallo said:Who would be doing the installation of the ECU? And who would be tuning it?? There are a lot of people out there that know how to tune AEM well....
ToMuchBoost said:Haltech, sells some very cheap and very good StandAlone.
While the AEM is @ the $1900 range the Haltech is @ the $ 1100 range ,and it comes with it's own harness, and the best thing is that it uses GM type of sensors ,so sensors are cheaper and you'll get a map sensor no more MAF.
where the hell are you getting that AEM costs $1900??? I think you can get it most places for ~ 1300 and some cheaper.ToMuchBoost said:Haltech, sells some very cheap and very good StandAlone.
best place I found was $1500 onlineRocky28072 said:where the hell are you getting that AEM costs $1900??? I think you can get it most places for ~ 1300 and some cheaper.
hasaabturbo1 said:Just get MegaSquirt!!!! Under $300 if DIY![]()
Hey Jeremy, what injectors are you running with your Map ECU? I just spent ALOT of time tuning my MAP ECU for my 525cc injectors and I'd be more than happy to Give you my base map for a starter point for you if you'd like. I got it running prety good now, I few lean spots under vaccum and alittle rich under boost but you'd have to fine tune it for your car...MAP ECU= :bigthumb:jeremyhelling said:I plan to run MAP ECU (that's already in the garage) once I get the rest of my turbo set-up and my goals are ~500rwhp at higher elevation.
Those are what I plan to run too. That would be awesome but I'm not sure how well it would work for me at high altitude. What turbo are you running?NinetyFiveNA said:Hey Jeremy, what injectors are you running with your Map ECU? I just spent ALOT of time tuning my MAP ECU for my 525cc injectors and I'd be more than happy to Give you my base map for a starter point for you if you'd like. I got it running prety good now, I few lean spots under vaccum and alittle rich under boost but you'd have to fine tune it for your car...MAP ECU= :bigthumb:
