1 - 13 of 13 Posts
Bad Texan Boy
It's an urgent, I need to talk to someone who is a tire expert!
Eimon
Sound Awake
What's your dilemma dude?
MIX
Bad Texan Boy
Im thinkin to get Iforged 19x11.5 for the back, so I want to know if 305/30/19 can fit on Supra?
I dont know if I really want 315/25/19 since it's 25" diameter cause other one is 26" diameter.
295/30/19 and 305/30/19 are pretty same diameter but different width.
315/25/19 is pretty same diameter as factory 17" tire cause I checked on tirerack.
And yes, my rear fender will be fully cut, like alll the wayyy up!
Bad Texan Boy
Discussion Starter #6
305/30/19 will fit as long as you have the correct offset.
A +50 offset should work.
Thanks.
I checked on tirerack that Yokohama ADVAN Sport 305/30/19 ($427) has 12.7" section width and Yokohama ADVAN Sport 315/19/19 ($439) has 12.6" width.. I dont know why both same brand 305 is .1" wider than 315.. strange but I know the diameter is different.
305/30/19
http://www.tirerack.com/tires/Spec.jsp?make=Yokohama&model=ADVAN+Sport&partnum=03YR9ADSXL&vehicleSearch=false&fromCompare1=yes&place=5
315/25/19
http://www.tirerack.com/tires/Spec.jsp?make=Yokohama&model=ADVAN+Sport&partnum=125YR9ADS&vehicleSearch=false&fromCompare1=yes&place=4
So, another question is.. if I decide to get 315/25/19, the wheel should be +50 offset, right?
do u like the stretched tire look?
11.5 is overkill on a stock body supra.
305/30/19 is the recommended size tire for 11"
same with 315/25/19 since it has a smaller sidewall.
Bad Texan Boy
Discussion Starter #8
It does? I dont like stretched tire look.. On tirerack says 315/25/19 is good for between 11"-12" and measure width rim is 11.5..
ok nvm yeah go for the 11.5 and 315/25/19.
just tell iforged u have a stock body supra with cut fenders and want to fit xxx/xx/xx tires and they'll figure out the offsets to fit those tires for you.
thats what i did when i bought my iforged wheels.
Bad Texan Boy
Discussion Starter #10 (Edited)
Oh rly, what size and tire did you go with? Are you satisfy with your setup?
grr , Im confused... So, you're saying 305/30/19 (12.7" section width) is no good to go with 19x11.5 cause of stretched tire look?
Cause on the chart says 315/25/19 has 12.6" section width but both of 305/30/19 and 315/25/19 has same measure rim width which is 19x11.5.
I could ask one of the ppl at Iforged and see if they can give me a specific answer.
i went with 19x11 295/30/19
i should of went with 305/30/19
i prefer the look of a fuller tire.
it really depends on which brand tire you're going with.
nitto tires recommended me 305/30/19 for 11"
which tires are u going with?
Bad Texan Boy
Discussion Starter #12 (Edited)
Ya, it depends on what brand cause I have 19x11 SP-1 on my other Supra, it has Bridgestone Potenza RE960AS Pole Position 295/30/19 but the section width is 11.6", diameter is 26", and measure rim width is 10.5".. so, it's lil bit stretched tire.. If I go with other brand with 295/30/19, it would be wider than 11.6" section width such as Bridgestone Potenza RE050A (12.3 section width) and Continental ContiSportContact 2/3 (12.2 section width) but im not sure it would fit for my rear fender due to SP-1 offset.
Those numbers of width sections I want to get for Iforged is Yokohama ADVAN Sport.
305/30/19 (12.7 width section, 26.1 diameter)
315/25/19 (12.6 width section, 25.2 diameter)
good choice on tires. i went with PS2's
which iforged wheels are u getting if u dont mind me asking.
tell all this info to iforged and they'll handle the fitment for you.
1 - 13 of 13 Posts
