1 - 7 of 7 Posts
Just wondering how you connected the lines to the bc motor? Did you tap in your own fittings?
I've made them work for a blitz DSBC.
As for advantages: they can take lots of heat, won't blow off and yeah, they look good.
Disadvantages: they are expensive!
Mike
So mainly it is for look. I would thought it might hold boost better, because it doesn't expand like normal silicone hose.
i am doing the mod for heat resistance purposes.
I'm sure they don't expand seeing that it can hold 1500psi but as far as holding boost better? Maybe, but you probably wouldn't cure a problem of say.. boost spikes with it.
Mike
1 - 7 of 7 Posts
