briguy453 said:
I am in dire need for new tires as well, and my plans were to buy BF Goodrich g-Force T/A KD's but would something else offer better performance? I only drive the car on very nice weekends, so I'm not worried about water or ice.
What are the draw backs to each tire?
Nitto NT 555R Drag Radial
BF Goodrich g-Force T/A Drag Radial
Thanks in advance!
Brian
None of them will be GREAT in the rain, but since you don't drive in wet weather you should be fine.
The T/A KD's will probably last the longest, have the best handling, but a little worse straight-line traction than the drag radials because of the KDs stiffer sidewall. These are probably my top pick for a TRUE street tire (not a DOT approved slick or drag radial).
As for the drag radials...
The Nitto DRs will be in the middle of the 3 for longevity, handling will suffer compared to the KD's because of a softer sidewall, and middle of the road for straight-line traction because its a slightly stickier compound than the KDs.
The T/A Drag radials will wear out fastest, have the softest sidewall so handling will be worst out of the 3 with these, but straight line traction should be excellent because they are stickiest.
I've ran the T/A KD's and Nitto DRs on previous cars, the KD's I never had to replace, they were on the car when I bought it and when I sold it around 15k miles later, they still weren't in need of replacement. Nitto DRs would last around 9k-10k miles if I was nice to them on a previous car (not very many burnouts/trips to the race track)...
I'm running T/A Drag Radials on my current Supra, were on there when I bought it, and judging from receipts of when the previous owner had them installed and then when I had to replace them, they didn't even last 6000 miles.
