just looking for a count of people looking to do a fuel upgrade from stock or people who are just changing up there current setup .
if this is you what are your plans?
as for me i currenty run 2 fuel feed lines to the front (one -6 line for the new pump in the tank, and the stock line for the current pump in the tank of the car).
Im thinking about just using one Y adaptor to the outlets of the two pumps with in the tank and then run a single
-8 line forward.
The line will then get split again after the fuel filter into another Y adaptor and then into separate -6 lines and run to each end of the fuel rail.
will i gain anything from doing this mabe not but it might help in equalizing the fuel pressure that each end of the rail will see's.
what do you guys think ?
-8 line forward.
