1 - 7 of 7 Posts
I have stock ECU+VPC+AFC2 + FJO and 6spd. Car is 97 with T61.81ar on T manifold.
I tuned my car in 3rd gear for about 11.5a/f. But when I do a pull in 2nd gear I get different A/F's, and different a/f's in higher gears. Why is that happening? Some people say it's normal and some says that the A/F's should be the same in every gear. I hate to be running into 10's A/F in my higher gears, and loosing power.
Paul,
How does my exhaust smell
When comparing A/F in different gears, you want to make sure it is at the same engine load (boost level) and RPM. Not just RPM. It should be the same across gears if you factor in both.
How can the engine load be the same if it's in a different gear? Also I'm talking about thee same boost settings.
Never enough
That may be your problem. Are you sure you are seeing the same amount of boost in every gear?
1 - 7 of 7 Posts
