1 - 7 of 7 Posts
I have an 87 turbo with the Lex AFM/550 injector modification, a Cartech intercooler an HKS boost controller and an AEM wideband A/F meter. I want to run 15 psi boost but I find that I can only make full boost in fourth gear. It makes about 11 psi in second and 13 psi in third. Why is the boost depend what gear I am using?
well from what i have read on other threads the stock turbos are only good up to 12 psi after that it is just superheated air and the turbo does not function correctly.
Overlooked
^ It's called overboost. You basically start pumping hot air because the compressor size is too small on the CT26 to get over 12.5 efficiently. Any intercooler won't fix it either.
Check exhaust, make sure its at least 3" all the way, mine had a crappy muffler on it that bottlenecked flow and caused me to lose boost at high RPM, also check your wastegate actuator and look for boost leaks.
1 - 7 of 7 Posts
