so, ya, why does it?? i get how both parts work, but why do you need the chip? if the SAFC can tweak the fuel, thus compensating for the different sized injectors, boost, etc, then why does the VPC need different chips?? is it just for an easier base tune??
i thought it might have shifted the voltage curves to allow for a higher HP levels since higher amounts of air is needed, but it reads PSI, and the highest psi i have heard of used with the VPC couldnt be higher than 35psi, and i couldnt imagine that being out of the range of the normal VPC, so this idea is moot....
:1poke:
:1poke:
