·it vibrate a little under 70mph . Above 70mph and on freeway is very fuckig unbarable. I know my wheel is not bent so can it be my spring and shock?
My car does the same I'm thinking my rotors are warped, or that I need an alighnment.Suprahaha said:tire balance is fine. Tires are brand new and they r fine too, only had about 1000 miles on them so far. It doesnt vibrate this bad a while back now its getting worse each day( i feel so). My steering wheels virbrate too. damn.. bad luck
i dont think its the rotor cuz mine r new and i also had my alighnment done a month ago. Well, my car go straight w/o problem but it just kept vibrating. PISS ME OFF COME on expertsMy car does the same I'm thinking my rotors are warped, or that I need an alighnment
i know beacause its been like that ever since i bought the car. I had done so many times of alignment, and tire balance but same result. i had new rotor and brake pad on, same result. I swap the stock rim w/ 18 inch and new tires, still same result. Besides, i really dont think wheel weight came off or tire balance can cause the entire car vibrate like there is no tomorrow. Even my steering wheel is vibrating like hell.How do you know the tires are balanced fine? Maybe the guy rushed the job. Maybe one of the wheel weights came off. It's possible you hit a bump and threw it out of alignment also. Also it is possible the mechanics who did the alignment under-torqued the nuts and the car fell out of alignment.
I seem to have the same problem you have with your car, except I haven't alighned my car. Has your car been in an accident? Is your car dropped/lowered? Have you checked out the camber settings? Let me know, maybe we can both help each other out...Suprahaha said:
it doesnt really matter which gear i am in or in netural or not. it vibrates wheather i like it or not.. damn car.Does it happen while rolling in neutral? While in gear?
i have not check those cuz toyota didnt say anything when i do a 60000 major service. these might be why. thx manLoose steering rack. Bad ball joints or bad tie rod ends. Have you ever taken it to a mechanic?
no accidnet nor drop or lower. i had my car alignmnet w/ lance's spec.I seem to have the same problem you have with your car, except I haven't alighned my car. Has your car been in an accident? Is your car dropped/lowered? Have you checked out the camber settings? Let me know, maybe we can both help each other out...
Elejes, does the problem cause your rotors to run outta shape? I mean does your steering vibrate even more when you gently apply the brakes at those vibrating speeds?elejes said:I seem to have the same problem you have with your car, except I haven't alighned my car. Has your car been in an accident? Is your car dropped/lowered? Have you checked out the camber settings? Let me know, maybe we can both help each other out...![]()
Yes, it does vibrate, I guess I can check for rust on the calipers...ianong said:Elejes, does the problem cause your rotors to run outta shape? I mean does your steering vibrate even more when you gently apply the brakes at those vibrating speeds?
That sounds intresting, can you elaborate a bit more? Did you take off the caliper and sanded the inside of it? Why did the rust imerge, do you live near a beach? Please let me know so that I can look into my car and try to fix the pain in the A*S problem...suprafly79 said:I know what the problem is.....Had the same vibration on my car
just changed rotors brakes ,put on new wheels and tires..had alignment done........a few weeks after came the vibration.......
anyways the problem was my rear brake was locked on the rotor
thats the left side rear wheel.....the car still drove but at high speed it vibrate very heavy.....I took the caliper off and i had rust in it......used sandpaper to sand off the rust and now running smooth.....might have to chnge that caliper eventuallly.....
hope this helps....good luckkkk
