Static compression on the NA motor is around 9.5:1. With the turbo motor at 6.5lbs of boost it is 12.4:1. With the 550 injectors and the lexus AFM you can handle 25% more air, raising the boost to 8.125 and giving a static compression ratio of 13.2:1. This isnt even pushing it yet, as we all know. Add boost of stock value to the NA motor, we get a comp ratio of 13.7, barely above that of the Lexus AFM'd Turbo motor. And now you're pulling about the same power out of the NA motor as the Turbo motor at 25% higher psi.
Give me some feedback on this, no thread bashing please... I already know that past stock boost you need more serious tuning and that the NA electronics wont handle it. But for about 500 bucks you can slap on a turbo and go without serious problems, and be in the 250whp range very easily. And with the 7m's being very similar NA vs. Turbo, the stock internals will hold up.
You can always upgrade electronics to the Turbo later to go past the 250whp mark, and if you do the parts bought wont be wasted. I think this is a good start for people wanting to learn about turbos, not just slap parts together based on the reccomendation of someone that has slapped the same parts together. Thats not what a being a Tuner is about.... So... Read, learn, and finally do.. and if you fuck it up, do it differantly.
