1 - 13 of 13 Posts
I have a inovate lc-1 and all the sudden my reading are all over the place!!!!
Has the sensor gone bad
Discussion Starter #2
bump
vp 112 and somtimes a little aviation fuel its low lead 102 octane
Your Neighborhood Pikey
The sensor, IIRC, is only rated for 100 hours on that kind of fuel. Likely your sensor needs to be replaced. Have you noticed that it responds slowly as well?
- Chris
Discussion Starter #6
it just started doing it last night it does not work at all now, i oredered a new one from MVP this morning, but heres the thing if i leave it pluged in........it has good idle but bumpy every noe and then and if i unplug it ..it runs smooth as silk
Probably because with it plugged in your car is leaning out.
Discussion Starter #11
so why would this happen??? the wideband is not tied into ecu, it just tells me what my afrs are rite ?? but if the sensor is bad maybe its screwing with voltage
I don't know! I have my wideband outputting a 0-5v voltage to my AEM so it can trim fuel. I wasn't sure if you had set up yours to do something similar or not...
If it not's and the car still is acting weird, the only thing that comes to mind is that maybe it's creating some noise that's messing with your ignition.
Sorry, I wish I could help you more on that one. Perhaps check your ground and power leads to make sure nothing has come loose.
Discussion Starter #13
car run perfect i just tuned it so i know when im 20psi im like 11.6 11.8
and ive run it today
1 - 13 of 13 Posts
