·For example, is a stock supra flywheel compatible with an Arizona clutch? thanks,
Zach
Zach
Yes it will work. Great setup too. The pedal pressure will be increased but the clutch is very smooth and easily slippable.Supra93TT said:For example, is a stock supra flywheel compatible with an Arizona clutch? thanks,
Zach
Things like throw out bearing , clips and other things dont come with a flywheel but are items that should be replaced at the same time. These items could be used but since they can wear easily it's better to replace them. Flywheel bolts can be resused but it is better to replace them also. It's like pulling a water or or oil pump. It's always best to replace the gaskets. When ordering a stock flywheel from most of the distibutors they will let u know exactly what u need.Supra93TT said:Thanks Silver Orchid..... one more question...... When ordering a new stock supra flywheel, are there any other components that i need to order for the flywheel that don't come with it?
Zach
