1 - 9 of 9 Posts
Will these offsets work on a stock bodied/suspension-height supra?
Front: 17X9 +25mm offset
rear:17X10.5 +27mm offset
Tried searching didnt get exactly what I needed.
Need advise if these will mess up the scrub angle of the suspension.
Is it turbo? Is it stick?
It will be very aggressive... you can make it work if you're willing to put the effort in. Depends what your priorities are and how far you're willing to go to make it happen.
Discussion Starter #9
I run lower offers. The fronts will be fine but you will need to roll/cut your rears.
now when you say cut, is it the inner plastic wheelwell that will need cut or the curved in lip of the fender itself?
Does anyone see any negative effects on rolling the fenders to accomodate these wheels then maybe later down the line roll them further to maybe fit an 11.5 rear?
so any ill effects from rolling twice?
1 - 9 of 9 Posts
