Hey guys, getting some wheels, do you think they will fit without rubbing?
Fronts:
19x9 +38 with 265/30/19 tires
Rears:
19x11 +48 with 305/30/19 tires
Car is lowered 1 inch with Tein S-Techs and the rear fenders are cut.
I think this setup will clear. Let me know what you think? Or should I go with a slimmer tire in the front? I was told 265 tires are perfect for a 9 inch wide wheel.
· Is it turbo? Is it stick?
265 is pretty big for a 9 inch wheel... it'll bulge a little. i'd go with a 255 which should be very full and square looking, or a 245 will have a slight taper to it.
as far as fitment, yeah it should be fine. i dont have experience with that exact width/offset/tire fitment but judging by others, it should fit inside cut fenders without rubbng alright. the thing with this is, you just have to take an educated guess and try it out, then adjust accordingly.
So you don't think the fronts will rub with a 265/ 30 profile?
Depends on ride height really, but probably not. I have an 18x9 +31 with a 245/40/18... doesnt rub at all. The wheel is pretty flush with the inside of the fender and the very slight taper of the tire matches it up nicely inside the fender. My car isnt super low yet though so I cant tell you what will happen then.
As much as the outer fender, you also need to worry about the inner fender as well as the top of the fender liner when you start going really low. Its not an exact science since there are so many variables in play.
· Premium Member
Fronts:
Your front specs should be okay. "Sidewayz" runs 265/30R19 front tires with 19X9.5" wheels, 40mm offset. His almost fit flush.
