1 - 4 of 4 Posts
1- I removed my stock twins and saw a cylinder shape device with a gold button(solenoid??) in line with the rear turbo oil feed line. Is there supposed to be an electrical wire attached to this? I found a loose wire from the wiring harness that was hanging very close to this.
2- What colors should I see inside the turbo? should i see any oil? Exhaust side and intake side.
I have one that is black and dirty inside and the other that is clean inside.
I will post pics this evening.
Thanks in advance.
Acting my age
The wire is probably going to a rigged up oil pressure sensor.. Thats what the gold UFO shaped thing is. As for the turbos, sounds like you have one with bad oil seals.. The turbos should be blackish inside, but not really really black.
1 - 4 of 4 Posts
