1 - 8 of 8 Posts
i was changing my plugs today and 4 of the 6 clips (female ends) that clip to the coil packs crumbled to a varying degree... 20k ago, when i last changed the plugs, only two little clips had broke... now, at 90k the clips and the light gray retaining clips for the harness are all falling apart... also i noticed i could actually see a little bare wire right at the clip/wire connection of the harness... car runs fine with the wires just pushed in place but id like to make it right
now a couple questions...
1) how much is the whole harness and roughly how much labor is involved in changing it?..
2) can i buy just the plug with a few inches of wire and have a shop graft them into my existing harness?..
thanks in advance
90980-11246 COIL PACK CONNECTOR LIST 5.52 COST 4.08 EA X 6
82998-12440 TERMINAL W/ WIRE LIST 5.00 COST 3.70 EA X 12
82121-14880 ENGINE HARNESS LIST 1047.00 COST 780.00
thanks... ill call you when you get back from vacation for the light grey retaining clips, the 6 connectors, and 12 terminals with wiring (correct?)...
thanks again,
brian
Brian, you mostly just need the connectors, the ones that are 4.08 a piece. Every supra i've worked on has had those things crumple on me.
The gray "clamp" with the number "7" on it, is not sold seperately from the harness. This holds the group of wires to the coil pack brackets.
ok, guys... thanks...
1 - 8 of 8 Posts
