1 - 4 of 4 Posts
whats does a EA3 block represent
I suspect it's a one way path? like a diode alloweing power to flow in one direction only?? :rolleyes:
for example see right hand side/middle of page
http://www.mkiv.com/manual/1995_electrical_manual/I/95elec_084.JPG
also what does the upside down triangle with lettering inside represent?
the marks under the triangle indicate a ground
but what about the letters inside it? (does it corespond to what the positive of this signal is?
Thanks! :bigthumb:
Rectangles are various connectors. The upside down triangle are ground points. The letters and numbers are the location of the grounds. You need the associated pages and there will be a decription where the connectors and grounds are located.
ok gotcha ( I thought there might be somethign more to it, doh!)
thanks guys
1 - 4 of 4 Posts
