1 - 10 of 10 Posts
anybody know where i could find a wiring diagram to the ignitor on the twin turbo supra. i just need to know the order/diagram to the 4 prong plug on the ignitor. thanks
oups forgot..... i need the wire diagram for the aristo ignitor... it uses different colors... if anyone has an aristo motor n there car with the aristo harness, could you do me a quick favor and look at the four prong connector on your ignitor and see what color the wires are in order of clockwise
12
34 thanks
you cant use the aristo harness unless you have an Aristo car.. not only that i dont think there is a wiring diagram for one.. ive searched EVERYWHERE back in the days when i tried to splice in my NA 2jz harness with the aristo... didnt work..
what do you mean it doesn't work? why cant you use the ariso harness without the car. i have the aristo motor/ harness/ ecu/ and tranny. please explain to me why this setup wouldnt work in a supra? ... so far i have the motor in, and the harness hasn't had any problems other than some broken connectors that im trying to replace and thats why i was looking for the wiring diagrams. the only potential problems i have heard is that the car wont pass emissions, the speedometer might not work, and that the a light will come on in the cluster.
Do you have these plugs? not only would you have to extend them... you cant even use those plugs... (these are Aristo harness main ecu plugs..)
all the plugs you need are available when you get a front clip... when ordering an aristo swap with just the engine and ECU you ar missing the blck that the large Grey plug connects to.
cassio- who was banned is doing a full write up on it.....
maybe he will be unbanned so he can share his findings.... or not :lol:
extending the main block "yellow" connectors is needed, as well as the "grey" block.
there is a second connector the "grey" block goes into.... researching what power etc this goes to, then there is another smaller connector that comes off into the ECU.
you can kinda get a jist of it in this image on mkiv.com
i vote unban cassio :)
12
34 thanks
for the 4 plug connector on cassio's igniter the colors are
1(Blk/pink) 2(black)
3(Grn/Ylw) 4(Lt. Brwn)
here's a PDF for a JZS161 aristo 97+ for the starter and ignition.
its in katakana and kanji and he hasn't translated this page yet.
http://ibconceptions.com/supra/2jz/3_3_starting and ignition.pdf
search google for kanji colors and you can just match the symbol to the color.
-ghost of cassio :sadance:
1 - 10 of 10 Posts
