Hi folks,
I know this has been asked many times before but the search isn't netting me any results.
I removed my twin flexalites and opted to go with 2 zirgos. The way I had the flexalites installed was to turn on via thermostat switch. The problem with this is that I cannot run my A/C because the fans only come on at certain intervals (activated via separate temp sensor I installed in my lower rad hose). I do not want to wire the fans to stay on 100% of the time so that option is not the way i want to go (unless I have to).
So Question # 1
Is there a way to wire the fans the same way I had before but to add a trigger/wire to turn/keep the fans on when the AC is turned on? And where would I find this wire/trigger source?
Question #2
Is it recommended to use 2 separate relays (1 for each fan) or can I just wire them up to run off of 1 relay only?
Thx.
Danny
So Question # 1
Question #2
Thx.
Danny
