No, you want to put the e-Manage on the line that the VPC sends to the ECU. In other words, you want the e-Manage on your KV freq stream, not the MAP stream. The VPC should have 2 AFM related wires, one that runs from HKS's pressure sensor and the other that runs to the ECU which tricks the ECU into thinking the KV AFM is still there. Unfortunately the signal the VPC sends out is a little choppy and distorted sometimes, but the e-Manage will automatically clean it up a little for you.
Profec e-01 is definitely the way to go in combination with the e-Manage.
