Who has the vpc emanage working. I need wieing diagram for emanage and vpc . I'm using the vpc wire harness.
This is what I was referring to.. I believe the same thus going with same setup.. I hope I can go ahead and get my Emanage in so I can sell the GCC and get everything setup...QWIKSTRIKE said:Thanks Tech I just used the vpc to eliminate the stock afm. I've seen post where some people have done this. Im just using the vpc as a map sensor and using the emanage to do all else. I truly believe no maf is better.
