21 - 40 of 74 Posts
Slo-vertible Drifter
Also as a follow up I've put over 6000 miles on my harness since the refresh. I'll take some pics and see if I can find any trouble areas. Otherwise everything just glacing at it still looks great.
Awesome. Think you could click a pic or two of it? Then I can add the pics to the top.
Gnome,
Can you post part numbers and how much of the mesh you purchased from cableorganizer.com? Any reccomendations on what else to buy for doing this?
Thanks!
I used this:
http://cableorganizer.com/expandable-sleeving/
http://cableorganizer.com/nylon-wireloom/
But were there was heat I took extra caution.
I also used some heat reflective tape. Which I may use more of.
Also get the heat shrink with adhesive if you don't want the mesh slipping around. I opted out because I'm going to refresh my harness again when I go single turbo and EMS.
If any one is too busy to do it yourself send me a PM and tell me what you want done. I'm a college student who now has to pay tution and support my habit of driving fast. ;)
THE NOTORIOUS BHP
Looks like the cableorganizer.com stuff is flexible and much cheaper than the non-flexible stuff from cabletiesandmore.com. Cableties product is also cut along the entire length for easier access later, but will it stay together overtime without zip ties hmmm
Where can I buy the connectors
Good day
I am new to this forum and would like to say hi to all off you.
I live in South Africa where parts for the 2JZGTE are very limited and virtually impossible to find.
My current project is rebuilding a 2JZGTE single turbo into a Nissan 200 SX.
Can you direct me to a supplier for the electrical connectors as mentioned below as Toyota South Africa can only import the complete wiring loom at app R14000.00($1866.00)
Oil Level Sensor 90980-10532
Throttle Position Sensor 90980-10711
2 x Cam Sensors 90980-10947
Crank Angle Sensor 90980-10947
Back-up/Reverse Light Switch 90980-11051
Coolant Temp Sensor 90980-11062
Speed Sensor 90980-11143
Idle Air Control Valve 90980-11144
Ignitor 90980-11151
2 x Knock Sensors 90980-11166
Coil Pack Plug 90980-11246
Alternator 90980-11349
Oil Pressure Switch 90980-11363
Starter Motor 90980-11400
Coolant Gauge 90980-11428
One last question?
How good is the Toga bearings for these engines as the only ones locally available is the ACL race bearing.
Thank you
Regards
Riaan
Supra OG
Wow, this is very good info. Does anybody know if the connectors for the lights, turns signals are also available separately from the body wiring harness?
Dr. Jeff Lange
Almost any connector on the car is available separately.
Jeff
hey Gnome, what size tubing and sleeves did you order?? im in the process of doin the same thing as you... also what size heatshrink?? thank you in advance...
Moderator, l337 M0d3r4t0r
Anyone know the part number of the clips for wiring loom that goes over the coil packs are?
They say 7 on top of them and crumble on contact with human flesh.
Also looking for the Aristo injector clips part number.
Supra OG
This thread rocks!
21 - 40 of 74 Posts
