1 - 10 of 10 Posts
Hey does anybody have a online diagram to hook up the avc-r/ safc II I went to apex'I.com and they don’t have the listing for the jza70 harness and ecu... Can anybody shed light on this that would help a lot of folks out who have a avc-r and safc II for there 1jz….
Akai Suisei - 赤い彗星
did you buy another JZ car clint? :)
I wish I did bro but im trying to help out a kid that needs to hook up the avc-r/ safc he doesn’t have the manual or this wouldn’t of been posted. But soon Joe I will own another JZ it will just be a wile, still trying to get my finances together.
I can do a write up but will post it up later tonight if thats okay with you. Ihave both in my car> Is this a 1jz Supra or a soarer since I think the ecu is different..
hey thanks its a supra 1jz and a write up will be awesome :) thanks
DRiFTT
getting my safc2 sunday, write would be 1337~!
bump still waiting for the write up :)
Are you sure it's not on their website? I used their website less than a week ago to put in an SAFC in a Mark II Tourer V 1JZ and it was there.
I think the safc is on the web sit but not the avc-r :(
Okay the AVCR has 7 wires
RED...............Power
Purple..............RPM/Injector Signal
Green...............Ground
Black.................Ground
Gray..................Gray
White.................Speed signal
Orange...............Scramble boost.
Download the SAFC and it will tell you what wires go to what EXCEPT for the White. For the white, download the REV/SPEED Meter PDF and it will show you which wire to tap into for White.
SAFC You will cut ONE wire on the wiring harness. The rest will all be tap in.
AVCR You will ONLY tap into the wiring harness.
Hope this helps a bit.
1 - 10 of 10 Posts
