1 - 10 of 10 Posts
i have an 88 supra turbo...my old turbo seals blew so the car had sat for a lil while but i finally put it back together with a gt35r. when i went to turn it on it kicks over but turns right off. if i give it some gas as im cranking it, it will start but wont run right at all until over about 2000 rpms. before the repair it ran fine even with a huge a/r 1.15 compaired to the gt35r which has a smaller hot side, not sure what a/r that one is off the the top of my head. some one help me please, also please let me kno if the video doesnt work. thank you
· The Great Kruso
You posted a link to your email account. You have to upload a video clip to the file sharing site such as Youtube for us to be able to see it.
· The Great Kruso
· The Great Kruso
It sounds like a cold start issue, have you gotten it to operating temps and is it still doing the same thing?
· Slowly but Surely
Did you take off your intake manifold (upper or lower)? I had this happen to me and the car ran the same exact way as im listening to in the video. Turned out that the lower intake manifold gasket was bad and air was escaping. I found this out by spraying carb cleaner around places where I thought leaks can happen. While spraying, listen for when you hear the idle rise. When it rises, you've identified one source of a leak. If you have an questions, PM me.
1 - 10 of 10 Posts
