my fabricator has a whole bunch of solid alumiun the right size for our mounts
just seeing if there was any intrest in this since im making mine up as we speak price would be 75-100 alot cheaper then what you can get online if intrested pm me or post peace
Captain Hammer
Might also want to explain the pros and cons of solid mounts...
the technical info is out there basically metal mounts never need replacing,cheap replacement, i have heard with solid mounts no need for a flex pipe on dp. Cons: vibration felt thru steering and shifter during certain rpms
even simpler hole drilled thru solid aluminum im using 21/2 dia with a hardened bolt thru it and washers just offering it to people since i noticed the price on some websites they wanted like 150.00 i think is robbery might be able to lower the price some more if ther was enough intrest
