1 - 4 of 4 Posts
Senior Member
Would these fit without any rubbing issues?
Fronts 18 x 9
39mm Offset
245/40/ZR18
Rear 18 x 10
44mm Offset
285/35/ZR18
OK everything should be ok as far as fitment. The only thing you want to look for is in the rear. when the car squats like on a launch or something of the sort you suspension travel might go down to low and slice the sidewalls of your tire. have a few friends load in the back seat see how low it will go. at the max you may need to roll your fender lip.
1 - 4 of 4 Posts
