Continuing to go through the 89 with 7MGE I picked up last year, I spotted this surprise recently.
So this is one of those deals where you send your ECU and good money to the performance tuner along with the list of what you have changed on the car and they magically tune your ECU perfectly to match and send it back for claimed 10-15% power gains.
So in my case, the "modified" ECU ran the car last year, but with some caveats...
After putting the intake and exhaust back to stock last year, adding back a catalyst and installing a new and properly located O2 sensor, I had been wondering why I still see evidence of high soot on the new spark plugs and light soot collecting on the rear bumper between car washes. All of the sensors on the car test out good and there are no codes.
The engine also sometimes cranks a little long and can stumble to a start hot. As for power I would say its adequate but definitely not over what I would expect form a stock 7MGE. Unfortunately I have not gotten around to buying and installing a UEGO yet although my new down pipe has a boss for it. I will add that to the list of to do over the winter.
Of course I couldn't wait to blow past the Void Warranty seals and see what was inside this.
Pretty much looks like a stock ECU (compared side by side below with another 89661-14320) . No daughter board in the ECU or piggy back anywhere in the car. The harness is unmolested and I am thankful for that.
These ECUs cannot be reprogrammed, the ROMs are one time burn. Possible someone installed a different ROM but all of the chips look original. I don't see the board coating or soldering disturbed anywhere and no sign of a re-soldering job, it all looks factory to me. I suspect that all that was done was to change a tuning resistor somewhere if even that. The one place where a resistor could have been changed without disturbing the board is R801 because it is a raised connection above the board. The performance trick is to enrichen OL fuel by changing to a higher resistance on the incoming IAT signal making the ECU think the incoming air is cold and dense. This "performance tune" would do little to help on the street because we all spend most of our time in the low and middle of the power band somewhere in CL fuel, not WOT. Of course performance and warning stickers were added and that's worth something to someone I suppose but definitely not what was charged for this. Makes me wish I had a chance to buy this car from the original owner who touched nothing.
------------ Stock 89661-14320 ----------------VS---------------- "Performance Mod ECU"
As far as physical differences lurking between these modules, maybe someone on the forum can judge that better than I can.
I installed a different stock ECU and it looks like an improvement already. The engine fires strong on first crank every time even hot using the stock ECU. I won't know the full story until I drive it again in good weather this spring. If I get the UEGO in over the winter, I might look at OL fuel during warmup on both modules and see if there is a difference.
