1 - 15 of 15 Posts
It's only the beginning..
Topic? Anyone know of one, or can make one? Thanks :D
Not so boring anymore
sure.. jack up the rear of the car.. put some jackstands under it.. get under there.. unbolt the bottom bolt (i think its a 22) drain the fluid.. put it back in.. unbolt the side bolt located at the back, fill with fluid.. lower the car.. go do 5 360 doughnuts and then your go to go..
lol
*I see you*
Yup. It's just like changing your oil minus the filter. Remove drain plug> drain> install plug> remove filler plug> fill> install filler plug> BOOST. hahaha Only thing I'd comment on is that it's more fun to fill the diff back up than the motor oil.
El Pollo Diablo
According to this threads 'brother' on SM, it is a 24mm ya need.
Im excited for the donut step of the process, my shits been peglegged for a while now.
and don't forget the LSD additive!!!
also, a pump helps...
Mines rusted to shit, I hope a breaker bar will work. What's this LSD additive I hear you guys speak of?
I was just gonna go to Toyota and ask for "Differential Oil for 1988 Toyota Supra"
yeah, remove the fill plug first. i did this becouse i was worried i might not be able to get it off with my tools at home. ended up at a garage and had to put heat to it. don't put to much there becouse it is alluminum.
good to know, i thought it was steel.
1 - 15 of 15 Posts
