Looking for the following
Vsv's and pigtail connectors
Resistor pack and pigtail connector
usdm 6spd harness
Map sensor pigtail
Ecu connector pins
HKS Type injectors
In process of rebuilding a de-pinned harness
Master Shit Fixer
Which VSVs do you want? I have one or two.
I should have all the VSV connectors and pig tails you need LMK what you need
I counted 5 on the motor (JDM) with one broken. So I will need all 5 pigtails and the broken vsv, which is the black one sitting on top of the rear turbo. I believe the US harness has provisions for other VSV's related to EGR. For those I will follow instructions to eliminate. So I need pigtails for the ones on the turbo side of the engine plus the one sitting on the vacuum pump.
