1 - 8 of 8 Posts
hey im looking at o2 sensors for the xerd header.. i got bosch 11027 universal ones... they have a black wire coming out of it .. but the stock ones have four wires.. a white, blue, and 2 blacks... i knew uhad to splice but after seeing 4 and only 1 in the bosch i dunno what to do... im in middle of it now so if u can help id appreciate..t hanks!
Discussion Starter · #2 ·
i did sesrch found some stuff... but did i get the wrong one? rwsupra told me that this is one to get...
ok i am confused reading what i found on search ... some have 4 wire some have 1 on o2 sensor... and they say they splice it into the one wire.. so do i take ALL four and connect to ONE wire on the 02? someone help me?!! i feel stupid haha ... if thas not wat u do then wat??
I told you the one to get for a what year car you told me you had. If you are 96 or newer, you'll have to get the universal 4 wire Bosch o2 sensor.
Ryan
now i juss heard i can use the factory ones .... i have a 95 and it has 4 wires... the one i got only has one .. so mebbe i try the stocks and see...
Well if you have a 95, they aren't the screw type so you'd have to get new one's. 95 is OBDI though so they should have the one wire sensor.
Ryan
We got it figured out. The 95 Cali Model has the 4 wire sensors and are also screw in type. If you have a Cali model with the 4 wire sensors, you can use your stock o2 sensors on the XERD header.
Ryan
1 - 8 of 8 Posts
