·Philip long 2 step,ETTC mod in TTC,pulled hose = 20.4 psi in first alone.It felt good but I smoked my clutch.New one on the way.I just thought you guys would want to know.
Joe
Joe
What tires were you using when making that boost in 1st gear. I guess you must have been hooking up really well.TTBADBOY said:Philip long 2 step,ETTC mod in TTC,pulled hose = 20.4 psi in first alone.It felt good but I smoked my clutch.New one on the way.I just thought you guys would want to know.
Joe
Actually you can use the 2-step on the street...I use it to be more consistent in my launches...you just have to find the right rpm for your set up, that goes for the street and the track. I build 4psi @ 4800rpm and that works pretty well for me on the street, but the key is that I can do it every single time and be consistent about it.TTBADBOY said:Bald drag radials.Actually, I was smoking the hell out of them.You wont be able to use the 2-step on the street.It just lights em up,but at the track with good tires its nasty.
Joe
