Status
Not open for further replies.
1 - 20 of 25 Posts
Supra Fan
Yes My MK3 Is For Sale. Tons of Mods. 450 miles on built motor
Yes Believe It or not my mk3 is for sale. I spent the last 2 ½ years building the car and the motor. The entire motor and performance parts only have 450 miles on them, so everything you see is basically brand new. The engine runs immaculate, there are absolutely no problems with it. Ive owned this car for 4 years. Im am selling the car because I have slowly lost interest in it. Dont flame me but I plan on picking up a new Lexus IS in the near future, so unfortunately she needs to go. Even though I am selling the supra, I will still be here on the forums. The car just spends all its time in the garage and is barely driven. Car is tuned and holds a solid 11.5 a/f under WOT. It moves nicely at the 15 psi I have been running it at.
Car Specs
1990 turbo, targa, 5 spd.
Transmission: R154.
Exterior Color: Black Mica
Interior Color: Grey
105k miles on the body and ONLY 450 miles on new motor and performance parts.
I am the second owner.
Engine (Only 450 miles on everything)
Started with a JDM engine that I bought specifically to use for a rebuild. It did this so that I would have a perfect crank to worth with, and a head and block that had never been surfaced before.
Ross Forged Pistons w/ Ross racing rings @ .005 ring gap.
Cometic 2mm MHG
ARP Head Studs
ARP Main Studs
ARP Rod Bolts
Race prepped stock rods
New Genuine Toyota overhaul gasket and seal set
New OEM engine wiring harness
New OEM oil pump
New OEM main and rod bearing set
New OEM main water bypass pipe
Every single oil and water hose on the motor is brand new from Toyota
New OEM motor mounts
Stainless steel 3rd valve cover
Machine work for longblock
Extensive powdercoating
New o2 sensor with adapter
Brand new battery and starter cables and ground wires
Hot tank and Bead blasting for all engine parts
Flywheel and exhaust manifold surfacing
New OEM new fuel pump bracket and lines for tank, new fuel filter, and fuel filter banjo line
Ngk plug wires
New timing belt and tensioner
Brand new alternator
New Belts
New water pump
MUCH more that I cant remember at the moment
Transmission
Stock r154 w/ spec stage 3 clutch, and redline mt-90 oil
Engine Performance parts (all have 300 miles on them)
SP61GT turbo w/ oil line kit
Custom aluminum intake pipe w/ filter
Custom 2 ¾ inch aluminum intercooler piping with 24x12x3 Intercooler.
HKS ssqv BOV -
Aeromotive adjustable fuel pressure regulator with custom -6an braided fuel lines. FPD removed, and J-tube, and walbro 255 pump.
BIC downpipe
Blitz Nurspec catback exhaust (only 2000 miles)
Lucas 550cc injectors w/ clips
Custom -6an loop line for stock turbo water ports
Spec stage 3 clutch
B&M oil cooler w/ custom mounted, w/ lines.
Suspension
Eibach springs w/ kyb struts all around.
Cusco rear strut bar replica
Ebay front strut bar
Electronics and Tuning
MAFTPRO w/ speed density
PLX m-300 wideband
Autometer sport comp electric oil pressure gauge
Autometer sport comp electric water temp gauge
Autometer sport comp boost gauge
Autometer voltmeter gauge
Exterior
Greddy Gracer replica front bumper
Bomex whale tail replica
New front front mud flap/panel
Misc maintenance and parts:
- New front brake lines
- brand new wheel bearings all 4 corners
- new inner tie rods
- new driveshaft carrier bearing
- ton of other stock parts replaced that I cant think of at the moment.
Interior
Reverse glow black face gauge covers
Aftermarket Gauges (listed above in “electronics and tuning”)
Grey cloth seats out of an 88’
Pioneer cd head unit
New leather e-brake boot
Aftermarket shift knob
new center console cover skin
no back seats
What needs attention:
The front bumper and whale tail are in black Gel Coat and will need paint. But look ok as they are. There is also a small rust spot on on of the rear quarter panels(pictured below). the blitz nurspec exhaust has a small ding on the muffler tip(pictured) Also I believe the front brake rotors are warped. ALso there are the common miscellaneous dings that you would find any 16 yeard old car. Besides those issues the car runs like a dream.
______________________________________
I have calculated a total of OVER $16,000 total invested including the $3,000 I originally bought the car for.DONT FORGET THE INCREDIBLE AMOUNT PERSONAL TIME AND LABOR I SPENT ON THIS CAR !! If I were to count that in it would be much higher.
I feel bad that I spent over 2 1/2 years building the car, and am now selling, but hopefully the car will go to a good home. Like I said all the performance parts including motor only have 450 miles on them. Everything was broken in properly, and there are a few people on these boards who have seen the car in person and that can vouge that this motor is in 100 percent working order. THe car does NOT even need tuning. My wideband is connected to the maftpro and the afr tracking is working flawlessly. I believe with the current setup the car should make about 500 whp at 21-22 psi. This motor can easily handle 600whp. I did not take any shortcuts building it.
PRICE - $9,000 FIRM.
I will NOT go lower in price. I have almost double that invested and everything is practically new. I think the price is more than fair, and if I could of bought this car 3 years ago for 9k I would of in a heartbeat. Serious prospective buyers can come over and take a test ride with me, and I would even be willing to do a compression and leakdown test in person to confirm the condition of this motor.
Car is located in Central New Jersey. If it does not sell within 4-8 weeks I will conduct a massive part out. PM me if you have any questions, thanks
- Steve
Supra Fan
pic of engine before installing brand new toyota oem new engine harness
I gotta say sorry to see ya leave the mk3 scene. Im gonna hate to see your car in anothers hands. I can vouche for steve on this car. Very intellegent guy and I can say that im sure this car will last another 15-20 years. Nice piece of work steve. Sorry to see it go. Someone is gonna have one hell of car and if you ask me even with that body work u pictured 9k is still a little too low.
:faint:
fbody to supra to fbody
Damn first me now you?! Oh well you'll see the light and keep it... I did ;) Kidding, but good luck on the sale man, sad to see it go was looking forward to seeing it this spring at e-town.
-J
Supra Fan
Discussion Starter #9 (Edited)
-J
Thanks. If the car isnt sold by the first e-town meet (end of may), I will be there with it. It will be sporting a F.S sign though. :). take care
_________________
the oem targa tool is also included with the car. :)
rip supra, new car soon
i'm going out to buy a lotto ticket, if I win i'll pay double asking price 'cuz that car is drop dead gorgeous. Your better be praying for me that I win the lotto this weekend.
1.5JZ Turbo Supra
i agree! I 2nd that! Im in jerzy i'll buy it for 20 K pickup if i win the lotto! Damn thats a sexy car!
Supra Fan
Discussion Starter #14
Thanks guys. ;)
Also, I forgot to mention that the alternator is brand spanking new, so I added that to the list. :)
would you be interested in a trade for a BPU 1998 Eclipse Spyder GST very clean which just turned 92k on it? very clean with well-managed mods...let me know if theres any interest. Also in central jersey...currently a student at Rutgers NB.
Supra Fan
Discussion Starter #16
No Thanks....:)
- Steve
Supra Fan
Discussion Starter #19
sicksupra1 said:
Clean Title? Can I get the VIN number please? Im VERY interested
-Taylor
pm sent
Supra Fan
Discussion Starter #20
Update:
If the car does not sell by Next Sunday (April 23rd) I will begin a massive part out. I will keep everyone updated...
- Steve
1 - 20 of 25 Posts
Status
